Pull_Up said:If you are currently in the "calibrate before every flight" camp then carry on as normal. If you are in the "don't calibrate if last flight was fine and you're not flying miles away" camp then carry on as normal.
You haven't updated the firmware, simply activated a new mode. Obviously, as with any first flight of the day, a one minute hover higher than head height a few feet in front of you is always a good thing to see if you need to calibrate.
For what it's worth I didn't calibrate the first flight after activating the NAZAM mode, but I always do the hover test. If I've done a firmware update, though, I treat it like a maiden and calibrate appropriately.
As long as you are choosing an appropriate area for calibration then doing it is fine if you so wish.
I'm going to get of the fence, now - it's starting to hurt.
eflyer01 said:...comes from ppl (a) days, controls free and full of movement.
