Shimmying
Discussion in 'Phantom 2 Vision + Help' started by xstatic, Aug 11, 2014.
  1. xstatic
    I have a DJI Phantom ver 1 that at rest with blades spinning b4 take off is fine with the DYS gimbal. But once airborne it has a side to side vibration. It is not caused by the gimbal as i had the same issue with the Arris CM200. But now that i have a third axis, is there any setting to get rid of this shimmying. I did have acceleration set to 500 which alleviated the symptom, but yawing had uneven but fluid spurts. Anyone have a similar experience that they were able to rectify. I can't shoot video with this consistent shaking.
    Blades are perfectly balanced and motors are brand new
  2. 4wd
    4wd
    North York Moors
    I have an older phantom one and it's just so much lighter; I think you will always struggle to get results like the heavier P2 can - which has so much more inertia giving the setup more inate stability.
  3. xstatic
    Do you suggest I buy the phantom 2 shell?
  4. 4wd
    4wd
    North York Moors
    As much as anything it's the heavier battery makes it seem more solid I think.
    Not sure really, the time comes when it might be best to look at the more substantial model rather than keep spending on the P1
    You'd get a lot better flight times too.
  5. OI Photography
    Clarksville, TN
    Have you balanced your props?
  6. xstatic
    Perfectly balanced!
