Shell upgrade suggestions
Discussion in 'Pro/Adv Discussion' started by trentos31, Feb 22, 2016.
  1. trentos31
    Hey friends, this is my first post. I had my first crash yesterday, performing an orbit and ended up too low and in a tree. I knew it was going to happen eventually...
    Luckily no major damage, but the shell is bent in one corner and the propeller doesn't clear the hull in that corner now. My question is, since I need to replace the shell, are there any suggestions for mods or upgrades that I can't live without while I have the whole thing apart? Is a carbon fiber shell worth it? Anything else I should really do under the hood? I appreciate the suggestions!
  2. Meta4
    Meta4 Moderator
    Staff Member
    There's no carbon fibre shell available - and if there was, it would probably block GPS signal.
    Nothing I can think of to do under the hood.
  3. RoyVa
    Virginia
    When you get ready to change over... Take lost of photos and tag and number for re install. Good luck and have fun.
  4. auen1
    Nome,AK USA
    Ted4797 likes this.
  5. Ted4797
    Florida and New York
    I have done a couple. Take a piece of paper and outline the hull. Then put the screws where u took them out. It is not hard, if u take your time. Pull the cable clips out very carefully. I think there is a youtube video showing how to do it. The worse part is the new shell. It comes snapped together and is a bear to unsnap. Use a butter knife and put business cards in the part u do get unsnapped. It is easier than fixing broken gimbals!!
Similar Threads - Shell upgrade suggestions Forum Date
When DJI Upgraded shell and motors? Pro/Adv Discussion Feb 12, 2016
Dreaded cracked motor shell Standard/4k Discussion Monday at 9:21 PM
Replacement shell Pro/Adv Discussion Monday at 12:47 AM
ISO gl300b rc shell only Classifieds Saturday at 5:00 PM
Carbon fiber shell? Phantom 4 Discussion Friday at 2:44 PM
