Shaky gimbal
Hi everyone, so I recently got a Phantom 2 vision +. The gimbal is shaking uncontrollably and I don't know why. I did some basic research and fixed the horizon line in the gimbal. The gimbal is still shaking and I don't know why. I don't know if this matters but when I went to fly the camera actually just popped off with the cable being the only thing that's holding it on. Any help would be greatly appreciated!!
Sounds like the camera/pitch shaft is turned 180 degrees off.
( the pitch motor connects directly to the camera unit on the gimbal, these can easily be installed backward, causing a violent uncontrollable shake!
Remove screw, and turn 180 degrees, should fix your issue!
J Dot
:cool:
Is this what you're talking about?
No the picture above is a broken one, used it only as a reference. As you can see the shaft BROKE out of the motor to the side
Yours is still attached to your pitch motor, that is the shaft to turn 180, as you'll see it can be inserted either way, kind of a stupid design, but, who knows! Lol.
J Dot
:cool:
mactechnic
