Severe crash! Battery issue
Discussion in 'Pro/Adv Discussion' started by hudster, Jun 3, 2016.
  1. hudster
    West Pittston, Pa
    So a few days ago, I was flying my drone in my neighborhood. it was several blocks away, but I could still see it. The wind started picking up so I initiated return to home. As it was coming home, i quickly turned 180 and it started spinning out of control and crashed, it needs a new body and gimbal! I believe wind caught it at the same time as I turned it and I think it caused it to flip the Phantom upside down! Anyway, I put in a battery and I got a message stating it is basically a knockoff, which it is not. Do you guys think the main board is damaged and causing it to not recognize the battery??
    #1 hudster, Jun 3, 2016
  2. silverFalcon
    Make sure the battery is all the way in and is making contact with the two data pins on the aircraft. If these pins don't make contact with the corresponding data pins on the battery, it will show up as a non-DJI battery. It is also possible that during the crash, the motherboard was damaged and the data pins were disconnected from the motherboard. How is the aircraft behaving otherwise, is the battery error the only error showing up?
  3. MikeyOnline
    If you did a quick maneuver, it's possible that a prop flew off as a result of the sudden motor speed change. It's possible the wind put it in a death spiral but my gut tells me it might be more likely that it had a prop flyoff (if one was missing) or motor/esc problem (if all props were intact).
    Mike
  4. hudster
    West Pittston, Pa
    SilverFalcon I cant get past that warning to do anything else, basically when i try to have the motors rev up, that error message pops up. The original battery that was in it at the time is damaged, it wont turn off and has a crack in it. It isn't leaking, but it is outside anyway.
  5. hudster
    West Pittston, Pa
    MikeyOnline All the props were on, It is just weird that soon as I turned it around, it did that.
  6. hudster
    West Pittston, Pa
    [​IMG][​IMG][​IMG]
  7. hudster
    West Pittston, Pa
    Well it's been a few months later, I tried to fix it, and no luck. I just bought the Phantom 4 and this thing is great! Lessons learned from my past misfortunes:)
Similar Threads - Severe crash Battery Forum Date
Severe Prop Crash Standard Jan 30, 2016
Phantom 3 severe crash while performing auto take off Pro/Adv Discussion Jul 21, 2015
Severe video lag P3SE Phantom SE Dec 31, 2017
P3SE severe lag Phantom SE Oct 18, 2017
Found this wire is disconnected and partially severed Phantom 2 Vision + Help Jul 7, 2017
