Set up. Phone and tablet?
Just wondering if you need 2x devices to run the Vision?
One for FPV view such as an iPhone and the other to run the Ground station such as iPad?
Also does iPad mini fit into the clip on the controller for the FPV?
There is no ground station support for p2v yet. Just need a phone for now.
And no the mini doesn't fit stock clip
Thanks for the responses.
Just thinking it might be difficult operating both the Camera and the quads direction on the phone at the same time.
Guess we will wait and see what the software offers first.
i only operate the camera when the p2v is hovering... its not like you are doing both at the same time.. you set the camera on the subject and then you can pan with the remote if needed or chase or whatever it is you want to do...
I suspect that the Vision app won't have the control options that the iPad ground station does - the screen real estate is too small. I think it will probably be used for programming your waypoints and starting/stopping the programmed flight. I'm just guessing from the one screenshot DJI has released, mind you...
