Seeing The Propellers!!
Discussion in 'Pro/Adv Discussion' started by cassalatico, Apr 3, 2016.
  1. cassalatico
    I was wondering could you advice how to limit the amount of times the props come it to view while accelerating ? Also as I'm still quite heavy handed a twitchy when controlling the craft is there a way to smooth out and slow down the movement of the phantom whilst airborne?
  2. sandman259
    sandman259 Guest
    Don't full throttle it. That's the only time when I see them is when I'm going full blast forward...
    Tony Cowan likes this.
  3. Meta4
    Meta4 Moderator
    Staff Member
    The Phantom tilts to go faster.
    More speed = more tilt.
    If your camera is aimed up where the propellers are in the tilted position, you will see them
    Try flying slower, aiming the camera downwards or flying backwards.
  4. Mako79
    Sydney Australia
    Look for Expo and Gain settings in the Go app.
    Change all Expo settings to 0.20. This will decrease stick sensitivity towards the centre of the sticks for refine controls.
    Another to is to drop the active braking to minimum (70% I think). This will allow the craft to continue with inertia and will give it nice fluid movement when stopping or changing directions. Make sure you practice in an open field as this changes the flight characteristics of your P3/P4.
    As for props - fly backwards and edit the vid.
    movius likes this.
  5. Air Ontario
    U.S./ Canada
    You can slow the initial movement some by extending the control sticks.
    Unscrew the locking nut and lengthen them, then tighten them in place
    You can reduce the sensitivity by lowering the Expo numbers in the Go App. Select quadcopter then adv. setting from MC menu, then exp and lower what you want to change from .40 to say .34 then fly and adjust from there
    The main control is just slow and easy stick movement.
    Or fly backwards
  6. alokbhargava
    San Francisco, CA
    Easy way is to keep camera positioned at -45 deg. This will help you avoid props visible on cam most of the time without changing your habits of flying.
  7. Tony Cowan
    Agreed. I used carbon fiber today. All props. But I was full throttle all the way home. About 36mph. I didn't care about video at that point. It wash race to get back as I was blind. I only noticed when I looked at video that props were seen entire way.
Similar Threads - Seeing Propellers Forum Date
Cannot see what camera is seeing in screen Phantom 4 Pro Help Aug 8, 2017
Not seeing map/satellite screen on my table screen - help Pro/Adv Discussion Jul 13, 2017
Realistically.... In a crowded urban environment. What kind of range are you seeing with P3P/P3A? Pro/Adv Discussion Mar 5, 2017
Seeing a lot of problems on P4Ps.. Phantom 4 Pro Discussion Feb 13, 2017
Not seeing latest firmware? Standard/4k Discussion Dec 31, 2016
