See one prop in video on acceleration
Discussion in 'Pro/Adv Discussion' started by Consultant, Oct 4, 2016.
  1. Consultant
    I've got about 10 hours on my P3A. Had only one mishap where on take off a prop came up so it tipped and skid a couple feet on the pavement and then stopped in the grass. Virtually no damage to even all the props. Just a few knicks here and there. Since then I noticed one flight that I see only one prop in the top of the video under heavy acceleration and sustained high speed. So it's almost as if the thing isn't flying completely level but it flies straight as far as I can tell. Suppose I need to do more testing with spare props, etc.
    What's the most likely cause(s) typically for this type of issue?
  2. Numone
    Surrey, England
    Have you recalibrated the gimbal? If not, do this and see if that helps.
  3. Trackman1
    Ontario, Canada
    I see this when flying in a cross wind.
  4. Numone
    Surrey, England
    Yep, that'll do it too. Come to think of it, I very often only see one prop, but I then lower the cam a bit and all's well with the world again! ;)
  5. alokbhargava
    San Francisco, CA
    Seeing just one prop is not unusual. All depends on wind direction. Check the same in still wind conditions.
    Calibrations on leveled surface will give you more confidence.
    Also check the props for any physical damage/ bends, deformations....
Similar Threads - prop video acceleration Forum Date
No propeller guards, slightly vibrating video? Pro/Adv Discussion Jul 17, 2017
Black props need more tightening? Video Added! Standard/4k Discussion May 23, 2017
Standard Propellers and Body Appearing in Video Phantom 3 Help Apr 22, 2017
DJI Phantom 4 Standard Prop Mount Upgrade Video Photos and Video Apr 18, 2017
Video of upgraded props on phantom 4. Phantom 4 Discussion Mar 26, 2017
