sd card size
It looks like the max size of sd card is 16gb. If not how do I change the size in the dji app to a bigger size.
There is no setting. Just insert a larger memory card.
I have a list of 16GB - 64GB memory cards that are known to work well in the P4 here. While most people are not using 128GB memory cards, some of them will work too.
Not according to the specs and the many users that use larger cards:
Supported SD Cards Micro SD
Max capacity: 64 GB
Class 10 or UHS-1 rating required
Although you can use larger cards, it might not be the best idea.
If you value your images, it pays to use several 16GB cards and swap them out each flight so that any disaster will only lose images from the latest flight.
Reactions: RémyHeli
I was on the road when I had to get more memory, and the Best Buy in Salt Lake City had a smokin' deal on a 128 SanDisk Extreme Plus V30 U3 XC1. I purchased it, and I was surprised it worked. I used it for the rest of my road trip, not having to worry about space since I wasn't able to upload my 3 16's into my home computer. I still use my 16's for use at or around home while the 128 is for the road.
