Standard SD Card issues
Discussion in 'Phantom 3 Help' started by IcantDo55, Jan 8, 2016.
  1. IcantDo55
    Va Beach VA
    P3s got for xmas, did firmware upgrade and It flies great but the only card that works in it is the 8GB SD that came with it?
    Tried a few different cards and same error. Wont even let me format them in the drone. Just says card error.
    Ideas?
  2. Noble 1
    Oregon
    Sorry if you already tried this, but format the cards on your computer first. I've ran into this issue before. When a format is done on a card it writes a bit of code essentially reseting/updating the firmware, even tho its not firmware at all. If you tried it on a PC with windows already, do it on a mac or with Linux or Android OS.
  3. IcantDo55
    Va Beach VA
    Tried formatting them on PC and a Chromebook. No luck.
  4. fordruid
    Wisconsin
    Off the wall guess but make sure that they aren't locked (write protected)
  5. IcantDo55
    Va Beach VA
    Not locked.
    BTW locked cards will not format.
    Thx
  6. fordruid
    Wisconsin
    Okay, saw this and thought not formatting at all.
  7. Noble 1
    Oregon
    So neither of the 32GB cards will format on the PC or Chromebook? Might be worth a trip to walmart to buy a new one, and test it in the store, and if it doesn't work then you know its your camera SD card reader. I thought the 1.6 update fixed SD card issues. Maybe try re-flashing firmware on the P3A if you still can't get a newer card to work.
  8. IcantDo55
    Va Beach VA
    Yea they all format fine on computer. Neither 32 can be formatted or read on the DJ1.
  9. Noble 1
    Oregon
    did you try formatting NTFS instead of FAT32?
  10. mudman
    Try copying the folders off the card that works then paste it on to one of the other cards and see if its recognised
  11. mudman
    did you do a quick or full format? I'm sure you need to select full format for it to work off a pc
  12. IcantDo55
    Va Beach VA
    I did not. Whats difference?
  13. IcantDo55
    Va Beach VA
    Thats a good Idea. I'll try it.
  14. mandalay
  15. IcantDo55
    Va Beach VA
    Thanks for all the ideas. I'll report back when I get a chance to try these ideas tmw.
    PS quick question. Do you have to do firm where up grade to each new battery? Got 2nd battery and it asked for firmware upgrade.
  16. fordruid
    Wisconsin
    Yes
    IcantDo55 likes this.
  17. MeiklesAndDimes
    Timonium, MD
    I had a problem with SD cards. Apparently some SD cards just don't work no matter what you do. I have had success with the Sony SR64UY2A/TQ. It's only like $22 on Amazon.
  18. IcantDo55
    Va Beach VA
    Just ordered one of those. Cant hurt, Lone Amazon!
  19. IcantDo55
    Va Beach VA
    Formatted fat32 (full format) and NTFS still SD error when installed in camera.
    If I try installing it in drone I get "Invalid SD card" in top right of camera screen. If I try to format in camera I get "SD card formatting failed"
    The working 8GB card it came with has no files to copy onto new card as someone suggested.
    Help
  20. MeiklesAndDimes
    Timonium, MD
    The phantom only support ExFAT and FAT32 formats. Due to the limitations of FAT32, I would recommend using ExFAT.
    What card are you having trouble with?
Similar Threads - Card issues Forum Date
SD card problems/issues Pro/Adv Discussion Aug 6, 2017
P4P+ controller SD card issues Phantom 4 Pro Discussion May 27, 2017
Memory card issues. And uploading Phantom 4 Discussion Apr 27, 2017
SD card issues Phantom 4 Discussion Apr 15, 2017
SD Card Issues Phantom 4 Help Aug 28, 2016
