Sd card issue
Discussion in 'Standard/4k Discussion' started by Tommo4316, Jan 29, 2016.
  1. Tommo4316
    Hi I'm thinking of putting a 64g sd card in my camera on my P3S do I need to format it or put any firmware on it before I put the card in or can I just put it in straight from the packet
  2. Tony Cowan
    No. Most cases it ready to go. Make sure you get one with a card reader or flash drive. Most come with it. Only way to go as 2.7k video files are large. And they will not transfer via wi-fi
  3. Tommo4316
    Thanks Tony
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It should work without formatting it. If you want to format it, it would be best to do it from within the DJI GO app.
    Since you have a P3S, you do not need to copy firmware to the memory card to install it. If a new firmware update is available, the DJI GO app will prompt you to install it -- and, download and install the update if you choose to do so.
    artheserenity likes this.
  5. RodPad
    Pacific,NorthWet, 97031
    Yes, as msinger says, any problems with it. Format with the app.
Similar Threads - card issue Forum Date
SD card problems/issues Pro/Adv Discussion Aug 6, 2017
P4P+ controller SD card issues Phantom 4 Pro Discussion May 27, 2017
Memory card issues. And uploading Phantom 4 Discussion Apr 27, 2017
SD card issues Phantom 4 Discussion Apr 15, 2017
Odd SD card issue? General Discussion Mar 17, 2017
