SD Card Classes?
Hi All
New to the P4 group was wondering if the P4 would be compatible with the new Video Speed Class SD cards?
Does anyone know if these are and if so is it advantageous to use them.
John
The P4 is only able to write at a max of 7.5MB/s, so there is no need to purchase the best possible memory card on the market. Any of the memory cards listed here will work.
The only advantage to the faster rated cards is that the read speed is higher which comes into play when you connect the card to a USB card reader that is capable of reading at the higher speeds. This can drastically reduce the amount of time it takes to offload the images and video from the card to the computer.
I use the same class 10 high speed card in my p4 as i do in my 4k digital camcorder. Works perfectly
cokersean20
