I must say after installing v3.06 I have had almost double the satellites I have ever had. I had 10 showing when I enabled the battery, and 30 seconds later it had climbed to 12 satellites. Nice to see some welcome improvements.
Helveticus said:Have you done the "aluminum foil" mod or is your bird 100% stock :?:
Anyway it's good news
StrikeTeam said:Explain to me how an aluminum foil mod would impact the copters GPS signal...
Sure, read this : viewtopic.php?f=27&t=19099&hilit=aluminum+foilStrikeTeam said:Helveticus said:Have you done the "aluminum foil" mod or is your bird 100% stock :?:
It does improve GPS singnal quite a lot I know as I've done it myself.StrikeTeam said:Explain to me how an aluminum foil mod would impact the copters GPS signal...
Helveticus said:Sure, read this : viewtopic.php?f=27&t=19099&hilit=aluminum+foilStrikeTeam said:Helveticus said:Have you done the "aluminum foil" mod or is your bird 100% stock :?:
dataway said:where did you get V3.06 I plugged my phantom in and it shows firmware 3.04 and lists that as the latest version?
Thanks' ! Just wanted to know if it's FW 3.06 alone or a combination of the FW + foil that helped increase the sats so muchflyNfrank said:Helveticus said:Have you done the "aluminum foil" mod or is your bird 100% stock :?:
No aluminum foil for my quad. I won't put ANY aluminum foil anywhere around my quad. I have personally seen too many weird stuff take place caused by aluminum foil. There is sensors that operate by reading the amount of resistance going into them, and aluminum foil can disrupt what goes on on both sides. Then there is also other antennas under the top cover. I could go on with this subject but I won't. I don't condone anyone that uses foil, I just don't use it for reasons mentioned.
