S2 switch not controlling ioc..
Discussion in 'Phantom 2 Vision + Help' started by Basically, Jun 28, 2015.
  1. Basically
    I got this drone a few days ago and after turning on NAZA mode, I'm having trouble getting ioc to work. All S1 switches work, but S2 is not. What can I do? Also, is there a way to set up manual mode to the S2 switch?
  2. N017RW
    Palm Beach Co.- FL
    If the switch is not working, as verified in the RCAssistant, it is typically a hardware problem with the switch itself.
    You can Google/YouTube for vids on how to replace it. (You may consider doing S1 as well while in there.)
    "Manual" mode can only be assigned to S1.
    Mako79 likes this.
  3. Mako79
    Sydney Australia
    +1
    And also check in the Phantom assist app. After you enable NAZA, you will need to check the IOC box. Turning on NAZA only enablles = ATTI mode/Failsafe/Manual. Ticking the box then enables IOC.
  4. RoyVa
    Virginia
    Yep sounds like the IOC block in the assistant software was not checked. Go back and verify.
    #4 RoyVa, Jun 30, 2015
