Hi Guys,
Phantom noob here. I have a Spektrum DX9 I'm trying to replace my stock tx with. I have both an OrangeRX R800x with S-bus and a Spektrum AR8000. I've gotten the R800X to bind and work correctly but I'm afraid to use it since I don't have the satellites for it yet. The AR8000 I've attempted to install using the Futaba SBE-1 for the S-Bus adapter but I can't get it to work correctly. I can get it to bind. On the P2 assistant monitor it shows the green dots on the AETR trims. But when I move the sticks the trims on the assistant don't move. X1, X1, and U don't move either. I've tried assigning to different channels but still not working. The SBE-1 led is a steady green so the connection is good. P2 assistant shows I'm in failsafe mode when I power on. How do I get out of this?
