Rx/Tx swap
Discussion in 'Phantom 2 Discussion' started by 2kvfr800, Feb 15, 2015.
  1. 2kvfr800
    Hi, I have a futaba T8FGS that is programmed for a DSLRPRO ultimate cinema edition kit, which is a Phantom 1
    Does anyone know if i can do a direct swap into a Phantom 2?
    Are there any control differences? would i have to any programming or would it be plug and play?
    Thanks!
  2. N017RW
    Palm Beach Co.- FL
    Yes.
    The P2 NV is sold with a 2.4ghz Tx/Rx.
    In fact since your T8 is FASST you can even bind it to the stock Rx in the P2.
    I cannot address any possible programming changes as I'm not familiar with the existing programming.
Similar Threads - swap Forum Date
Metal arm ends .... I will swap from my Std to my Pro - when it returns Pro/Adv Discussion Jul 29, 2017
Tough Motor Swap General Discussion Apr 30, 2017
Video Interference after ribbon swap. purple/pink/magenta with green Pro/Adv Discussion Apr 8, 2017
Non-HDMI Module swap Pro/Adv Discussion Mar 22, 2017
Argtek and DBS hybrid This way I can swap between the two and don't have to drill holes. Standard/4k Discussion Mar 21, 2017
