- Joined
- Jun 22, 2016
- Messages
- 1
- Reaction score
- 0
- Age
- 59
I am new to phantom 3. After play with Bebop, I decide to buy Phantom 3 standard to have it go. After load the DJI go, it takes a bit time to forward and backward to get the Drone registered. Update firmware and check RTH settings is 30m. Then, I did first fly test. Look ok even it is windly. I didn't let the Drone fly high, only below 10m. and only 10m away. When I try RTH (press H on smartphone), I got notification that the original position is too far away, and two options, orginial position or current position. I did highlighted "current position" hte drone just speed up and goes to sideway torwards bush trees. I am a bit afraid and try to get control back by flip S1 switch and didn't work. So low down the drone to ground for crash landing. a few attempt, it does the same thing and it goes different "current position". Now my question is what is orginal position Phamton 3 think, the start lifting spots? it seems not. And what is "current position" it define? The GPS signal says 7 to 9 all the time. Appreciated any comment.
