- Joined
- Dec 9, 2016
- Messages
- 38
- Reaction score
- 7
- Age
- 52
This is not a whining post or a nearly lost post, just a question if this is a default failsafe.
Background story:
So i went out and had a training flight with my drone where in doing the exercises in the dji flying guide and to get more confident.
Now i just got a argtek antenna mod , not that i think its the reason for what follows.
I also wanted to push the battery to see just how long it will keep yhe bird in the air (ie when the warning came on i kept it low about 2m or under but not hovering was doing manual circles around me as POI).
Any way due to the sun and the way the wind was blowing it put the drone between me and the sun when i went up 100m and out 100m, ( i have that set as my max distance as ill not need it to go further and the Argtek upgrade is mainly to try for good solid signal) anyway do to the sun i moved myself and where i was flying so i wasnt trying to find my drone with yhe sun in my eyes.
But i never changed/reset a new RTH point. My new spot also due to a building it was a sports club house was about 25meters from original.
So i am flying the low bat warning went off. I brought the drone fown to 2m/ish and about 5m away from me.
So i get the voice warning the drone was going to RTH in 10 seconds that was with about 15-20% battery life. So i started my landing which would have only taken about 5 seconds it was about 30cm from the ground then the drone went into RTH mode and climed to 30m and desided to head to original RTH point and NO MATTER what i did the drone would not come out of RTH mode, i toggled the switches = didnt work.. i tried the app = didnt work.
Thankfully it landed safely and did not fall from the sky, and battery was left with 12%.
So has anyone else had this?
Like i said this is not a whining post just a passing on a experiance that maybe someone else has had and can dhed some light if this is a fail safe or just a weird situation i was in and just lucky all went well.......this time.
Sent from my SM-G900I using PhantomPilots mobile app
Background story:
