RTH Behavior
Discussion in 'Standard' started by Flatwoods, Jul 23, 2016.
  1. Flatwoods
    Could someone parse the highlighted text for me?
    • RTH.pdf
      File size:
      2.6 MB
      80
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It's saying the following:
    • If your Phantom is within 20 meters of the home point when RTH is initiated, it will auto land at its current location instead of returning home.
    • If your Phantom is more than 20 meters from the home point when RTH is initiated, it will ascend to the set RTH altitude and then return to the home point. While it's ascending to the RTH altitude, it will start returning back to the home point right away if you press the throttle stick after it has reached 20 meters (and before it's at the RTH altitude).
  3. Flatwoods
    Thanks. The behavior of the second condition wasn't clear to me in the original DJI phrasing.
    The first one presents a dilemma for me as my backyard takeoff and landing real estate is limited to about a 5m chimney through the tree canopy. So if I'm more than 5m but less than 20m and RTH is initiated I'll need to respond quickly otherwise it'll be tree climbing time.
Similar Threads - RTH Behavior Forum Date
GEO Zones, and RTH Failsafe Behavior Alert Phantom 4 Pro Help Jun 12, 2017
Confirm RTH Behavior Standard Jul 20, 2016
RTH behavior Pro/Adv Discussion Feb 15, 2016
quick RTH behavior question Phantom 2 Vision Discussion May 9, 2015
Quick Questions, Flight Distance RTH Behavior Phantom 2 Vision Discussion Apr 16, 2014
