- Joined
- Feb 23, 2016
- Messages
- 254
- Reaction score
- 42
- Age
- 84
The Phantom's RTH speed is well below top speed and if you find yourself in a low battery or headwind RTH situation, you will do better to switch of object avoidance and push the right stick forward to get more speed.What speeds are Phantom pilots recording on RTH?
The Airdata blog post only looks at Minutes per Battery which is fine if you just want to hover nearby.There has been much discussion about the RTH speed for best battery use. The conclusion from PhantomPilots is faster rather than slower. Here is a link to a study of several popular models which shows a different result (article has been mentioned in another thread):
How does this fit with what others have been saying? Confused???
Drag increases 4 to1 over lift. Basic physics.Seems like the faster you go the more efficient it would be. At least for a p3\p4 type airframe. Its more or less a lifting body so increased speed means increased lift.
It all depends on how you define efficiency.Drag increases 4 to1 over lift. Basic physics.
You are correct. Not being a true lifting body, (having a lift producing wing), the Phantom, at slow speeds uses a tremendous amount of energy just remaining aloft. At some higher forward speed, it is fighting enough drag that it is wasting energy. Somewhere in the middle is the "sweet spot"; the maximum distance able to be traveled, for the least amount of energy use possible, to maintain altitude.It all depends on how you define efficiency.
The Airdata post looked at time per battery.
If you look at miles per battery, hovering or moving slowly is the least efficient because the Phantom uses most of its energy just to fight gravity.
The Phantom doesn't develop much lift from airflow over the body like a plane's wing does.
If you are interested in what speed is most efficient, this post is for you:
Best fuel efficiency tests
Thank you so much for the link to "Best Fuel Efficiency Tests". So, 13-14 m/s is the "sweet spot"for energy consumption. 29-31 mph.It all depends on how you define efficiency.
I've had 50 mph plus but that was on return from a flight into a headwind. Had a nice quick return.
Phantom 3 Standard
