Is the RTH altitude set from the takeoff point? Therefore, if taking off in a valley one must consider the high ground above plus obstructions I assume. Thanks from a new P3A owner.
Thanks for the reply. One more question if you don't mind. Will the 4k camera switch out with the P3A easily? Thanks in advance.That's correct. The takeoff point is 0 feet/meters.
If you mean the camera from the P3 PRO, yes, but you will need to then load the PRO firmware.Thanks for the reply. One more question if you don't mind. Will the 4k camera switch out with the P3A easily? Thanks in advance.
