RTH Altitude not working
Discussion in 'Pro/Adv Discussion' started by Dan Torchio, May 28, 2016.
  1. Dan Torchio
    For some reason, my P3P simply climbs to infinity when i activate the RTH function. I've tried setting to 200, 250, 300 max altitude. At one point it went to 600' and still climbing. I took control of left stick climb to stop climbing and it then returned home from that altitude safely. It's never done this before. The only thing I've changed is I've disabled the MAX distance option so I can fly much further. I'm updating firmware because the DJI App says firmware update required. Not sure if that will affect it as I've had it work properly last week when it also said update required...any suggestions or experience with this?
  2. MasterBlaster
    GA
    Remember, the RTH and max altitude is in meters. So if you are flying with imperial set in the settings (feet), RTH is still in meters so you have to do the math in your head. So, 200, 250, 300, would actually be 656ft, 820ft, and 984ft.
    Hope that's it :)
    Reed L and Oso like this.
  3. DennyBoBenny
    I was just typing the same thing when your reply came in. :)
  4. Oso
    Oso
    Western US
    That's usually the issue when we see this question. I sure wish they would fix that RTH setting to match the users preferences.
    MasterBlaster, sonof40 and Reed L like this.
Similar Threads - RTH Altitude working Forum Date
P4P 500m Absolute Altitude limit and Auto RTH Question Phantom 4 Pro Discussion Oct 9, 2017
Setting the RTH altitude when flying uphill Pro/Adv Discussion Oct 1, 2017
New App Update Limits RTH Altitude??? Control (Go, Litchi, etc..) Sep 21, 2017
RTH altitude Standard Sep 14, 2017
Litchi; Google Earth show no altitude for ... Control (Go, Litchi, etc..) Jun 12, 2017
