Put a new camera on my RotorPixel and it works great... but... The camera is tilted at a bit of an angle and I can't figure out how to get it straightened out... Anyone?
Thanks...
-slinger
Thanks to a post from DirkClod I found the answer...
EXPLANATION: The motion sensor that is on top of the camera mount (known as the inertial measurement unit, or IMU) is precisely calibrated at 21 degrees Celsius at our production facility prior to shipping. However, over time, at different temperatures, or after hard impacts, the sensor can drift away from proper calibration, causing the gimbal to think that "tilted to the left" (as an example) is the actual horizon.
SOLUTION:
1. Unplug the cables coming from the motors going to the gimbal control board (they are on the left side of the gimbal control board). Take careful note of their orientation and position.
2. Power up the Phantom.
3. Rigidly fix the camera in a perfectly horizontal position (do not just use your hands - make sure it is kept perfectly motionless).
4. Press the small black button on the back of the gimbal once quickly (do not hold it down... this will reset the board completely).
5. Wait approximately 5 seconds for the gimbal to re-calibrate itself. You'll see the green light on the gimbal control board flash for a few seconds, then once it is finished, the green light will be solid again.
6. Now, turn the Phantom off, plug in the motor cables into the gimbal control board, then turn the Phantom power back on.
Works perfectly and takes a minute or so... Thanks Dirkster...
-slinger
