Rotation speed
Discussion in 'Phantom 2 Discussion' started by captain_ken, Aug 10, 2014.
  1. captain_ken
    I would like to set my phantom2 to rotate slowly, as the input currently is far too quick for a smooth rotation especially circling objects etc, ive managed to do it for the HD/3D gimbal vertical axis but how do I do the same for the rotation speed of the phantom2?
    TIA.
    Ken
  2. adanac
    NYC
    There are others who may know better than me but my recollection is that you cannot change this with a stock unit. Changing the yaw gains does not change the speed of commanded yaw changes/rotation.
    I wanted exactly the same thing so I switched to a Futaba TX/RX. This allowed several enhancements which included changing the yaw speed in the radio. I use the T8J and the R2008SB, although I may switch to a higher end Futaba radio for various reasons.
  3. ElGuano
    +1. There are no atti gains for yaw, so you either move the sticks more slowly or use a 3rd party tx with customizable dual rates.
  4. HarryT
    Warrington, UK
    I must admit that when I read the original post, my immediate thought was to wonder why you don't just move the stick less. My P2 rotates extremely slowly with a small movement of the stick.
  5. OI Photography
    Clarksville, TN
    You can also try pinching the stick closer to the base of it rather than resting your thumb on the top, I find that helps when I need to be a little more precise about the amount of input I'm giving on any axis.
  6. Mike
    Good tip. Thanks.
  7. macheung
  8. FedeVision
    San Jose, Costa Rica
Similar Threads - Rotation speed Forum Date
4k Litchi Waypoint Mission/ Rotation Speed Phantom 3 Help Sep 1, 2016
How do you change rotational speed settings Phantom 2 Vision + Discussion Jul 29, 2014
Adjusting rotation (yaw) speed and sensitivity? Phantom 2 Vision Discussion May 2, 2014
Faster yaw speed ? Rotations - increase gains help?.. General Discussion Apr 15, 2013
Drone 360 rotation when Switching Gimbal Mode from Interpolate to Focus POI Photography and Film Oct 21, 2017
