right joystick no spring back
Discussion in 'Pro/Adv Discussion' started by greg r e, Apr 24, 2016.
  1. greg r e
    took my p3a out of hardshell case yesterday for a quick flight and noticed right joystick has no spring tension,and will not return to center on its on..never dropped or mishandled.3 months old.anybody had a similar problem,solution?
  2. SteveAikens
    Clovis, NM
    Not exactly, but similar. My right command stick dropped away from the connection to the top of the controller and moved up and down in the case. Contacted DJI, they replaced the controller in about three weeks. Most of that time was shipping time. As it turned out for me, weather was mostly a problem to fly anyway so it was all good. Brand new controller arrived, I linked it to the P3P and went flying. You will have to sent to DJI for repair/replacement. No user servicable parts in the command sticks.
  3. Mark The Droner
    It's a steel spring inside that must have broke or come loose somehow. It is probably fixable if you're willing to spend the time.
  4. N017RW
    Palm Beach Co.- FL
    Yea. It depends on your comfort with opening it up to see.
    Your can see photos and vids of opening the case and what to expect.
    Might be a simple fix.
  5. SteveAikens
    Clovis, NM
    Curious why some would suggest opening up the controller - that's under warranty - and risk having warranty refused because the RC was tampered with.
    #5 SteveAikens, Apr 24, 2016
  6. alokbhargava
    San Francisco, CA
    If tour RC is still in warranty send it back to DJI for service. Once you get it back , calibrate sticks again. In case you get a replacement, you will have to link to your P3 as well update its FW to match with rest.
    Stick your name sticker on back before sending it to DJI I case you decide so.
  7. N017RW
    Palm Beach Co.- FL
    If you have experience or simply a knack for fixing things you can probably remove a few screws and take a look. YouTube has lots of videos where you can learn.
    You have to decide for yourself.
    For example, I would never attempt to repair my car's transmission but I bet there's members here who could.
  8. MedinaTaylor
    Wait weeks, if not longer for the great DJI service center to possibly fix it under warranty.
    Or spend 15 minutes doing it yourself and get back in the air the same day
    Mark The Droner likes this.
  9. Mark The Droner
    BINGO!
  10. greg r e
    Thanks all gonna probably send it back since it's only a few months old, gonna contact dji first thing tomorrow
Similar Threads - right joystick spring Forum Date
Replacement right joystick phantom 4 Classifieds Aug 4, 2017
Beware of right joystick stick issue and how to fix Pro/Adv Discussion Nov 1, 2016
Right joystick changing Pro/Adv Discussion Sep 3, 2015
Move YAW to Right Hand Joystick? General Discussion Sep 17, 2013
7.85 High Brightness in stock CrystalSky Monitors Yesterday at 8:05 AM
