Return to Home ... question
I have a Phantom 2 Vision... everything works fine...however when I turn the transmitter power switch OFF... it does indicate coming home. But if I want to take control to land it or cancel " coming home" I can not. I have tried the obvious turning my transmitter back on... but the Phantom still lands on its own ... How do i get the transmitter to regain control ???
This is a risky way to do this. Doable but risky as you have experienced.
Have you setup Naza Mode with the P2 assistant?
If so then reprogram S1 for fail-safe at the bottom position then you never lose the 'link' with the aircraft.
I personally would consider enabling NAZA-M mode. I do not like turning the TX off as a normal function. I would rather flip the switch to Failsafe to start RTH and then just flip it back when ready.
cgarner1
