- Joined
- Jun 25, 2014
- Messages
- 50
- Reaction score
- 0
EMCSQUAR said:I did it months ago on a P2, it's more of a novelty. It did fly better when in up position, but when down the weight and movement made landings a little challenging. - http://youtu.be/3eZBqbN8gDU?list=UU_2vD ... VSNdmm127A
Dirty Bird said:EMCSQUAR said:I did it months ago on a P2, it's more of a novelty. It did fly better when in up position, but when down the weight and movement made landings a little challenging. - http://youtu.be/3eZBqbN8gDU?list=UU_2vD ... VSNdmm127A
I assume you were using an aftermarket 2.4 Ghz controller? If not, how did you toggle the gear with the stock controller?
ToThePoint said:Yes the not stock controller is clearly seen in the vid beginning.
Issue with a V+ is that its a 5.8Ghz R/C system.
Not found a after marked 5.8Ghz r/c yet, so almost impossible to implement it in a V+.
Or you need a second R/C and or command something to let the legs function.
Did you see the weight of them ? 188gr.
What are your going to do about that ?
locoworks said:ToThePoint said:Yes the not stock controller is clearly seen in the vid beginning.
I was wondering if some sort of sonar device could be fitted that lowered or raised the UC based on height from the ground? say 3 feet up??
N017RW said:Sure it's doable.
Look into small microcontrollers (Adafruit, etc.) and ultrasonic sensors.
