Resetting home position
Discussion in 'Phantom FC40 Discussion' started by darwin-t, Sep 4, 2014.
  1. darwin-t
    I have tried repeatedly to reset home position while in flight by switching S2 between Course Lock and Home Lock several times, but it has not worked.
    Any ideas why it doesn't work?
  2. 4wd
    4wd
    North York Moors
    You need to do it very quickly, usually five times will do it.
  3. wattage
    Scotland, UK
    Nope doesn't work for me either. Lots of PV2+ users reporting the same problem. Can't all have faulty switches.
  4. Damon
    Eastern Wa.
    Works for me. Use a fast cadence (5 down and ups) taking about a second and 1/2 total ending in the up position.
  5. wattage
    Scotland, UK
    Tried it many different ways, different speeds, different number of switch flicks, different end positions. None do anything. Same problem on my F450 with Naza V2.
  6. Damon
    Eastern Wa.
    Go from top position (off) clear down to bottom (h/l) 5 times.
  7. scooterbuk
    Edinburgh Scotland
    Works on mine, cheers
  8. 4wd
    4wd
    North York Moors
    It's all about doing it quick enough.~
    It works fine on my P1 and p2V+
    However it often takes a couple of attempts because the slightest misfire in the toggling and it doesn't do it.
  9. Rustysocket
    What is an indicator that the procedure was successful? Rapid flashing green lights?
  10. darwin-t
    Ah ha! That was where I went wrong. I was going from the middle to the bottom positions.
    Thanks!
    BTW, I replaced the switches with better (although larger) switches.
  11. Damon
    Eastern Wa.
    I call that great preventative maintenance ;)
Similar Threads - Resetting home position Forum Date
Resetting Home position! Pro/Adv Discussion May 13, 2015
Resetting home point Phantom 4 Discussion Mar 28, 2016
Resetting the Home point on PV2+ v3 Phantom 2 Vision + Discussion Aug 5, 2015
Resetting home point Pro/Adv Discussion Jun 13, 2015
Resetting Home Point General Discussion Jan 20, 2015
