Replacing standard filter. mine is cracked.
Discussion in 'Pro/Adv Discussion' started by Steve Bein, Nov 8, 2015.
  1. Steve Bein
    Hi,
    !st flight error and I cracked the lens filter. I do not want to buy the ND grad filter or other things, just want a filter with fresh glass. Can the glass be bought, or can a complete clear filter be bought.
    The only other filter might be the polarizer, but not necessary yet. My drone is the P3 Pro and the filter is removeable. So any further suggestions. I am quite able to remove the old glass filter from the aluminum body, if a replacement glass is available. OR a suggestion on where to buy the new filter.
    Any suggestions?
    #1 Steve Bein, Nov 8, 2015
  2. barefootbeachcombing
    US
  3. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Steve Bein, you just need a replacement UV filter. Your broken filter will screw off. Grip it as lightly as possible -- otherwise it will be very hard to remove.
    You can get a replacement UV filter from Amazon, eBay, or directly from DJI.
Similar Threads - Replacing standard filter Forum Date
Replacing Phantom 3 Pro with Standard body. Will it work? Pro/Adv Discussion Apr 11, 2017
Professional How to initiate the "Aircraft Initiation" after replacing pn #96 ESC board Phantom 3 Help Aug 4, 2017
Standard Help - Gimbal going crazy after crash (video) and replacing antenna wires. Phantom 3 Help Jul 28, 2017
Replacing TOP half of the shell Phantom 4 Help Jul 18, 2017
Replacing a Phantom 3 Professional Remote Pro/Adv Discussion Jun 8, 2017
