Replacing GPS Antennas
I apologize for cross posting, but wanted to see if anyone's got an idea about this:
I was wondering about maybe replace the GPS Antenna with one that has a higher gain.
I think this one below can be used to replace the P2V+ GPS antenna. However, am looking for something with more gain.
http://www.digikey.com/product-search/e ... .25.2.A.02
http://www.taoglas.com/images/product_i ... 190410.pdf
Like these, but not sure if these are too thick..This would also get the GLONASS as well, but not sure if GLONASS works with P2V+
http://www.taoglas.com/antennas/GPS-GLO ... h_Modules/
These are Glonass Antennas
http://www.digikey.com/product-highligh ... ennas/3704
This one is slighly thicker (by 2mm), but am thinking might work:
http://www.digikey.com/product-detail/e ... ND/3927214
Anyone have experience with this?
I think the GPS in the P2V+ is a ublox 6. I don't think it does Glonass or Galileo.
I was wondering if anyone has tried replacing the ublox 6 with a ublox 8 module that does GNSS, Glonass, Galileo etc... I'm not sure if the P2V+ firmware could work with it though. The ublox 8 is quite a bit more sensitive then the ublox 6 also and they are pin compatible. With all the talk of flyaways possibly being due to GPS error or loss of GPS signal having 20 sats instead of 6 sounds pretty interesting.
I am thinking even if the firmware can not handle GNSS, Glonass, Galileo, the added sensitivity would be handy.
My old Vision routinely gets about 12 satellite Vision+ gets about 6 to 7. At same location.
I get during the daytime 10 sats and 12/13 during dark times on my V+.
Anyway it could be intesting if they are pin compatible.
I didn't look into any upgrade for the GPS yet.
Have to deal other things first.
I love my PV2+ and that's with it spending over 50% of its time in the air in ATTI due to low sat lock.
I'm lucky that I'm confident flying it without GPS lock, if I wasn't I'd be a lot more pissed.
However when I start to spend more time using it for photography work, the intermittent GPS lock will start to annoy me as I will not be able to concentrate as hard on getting the photos that I want especially if its unlocked in a breeze and I'm spending a lot of time correcting its position when I should be concentrating on the iPhone.
Therefore, I am hoping for a GPS module fix OR a new Vision with better GPS.
Here's an older thread I found on replacing the GPS Antenna
viewtopic.php?f=5&t=920
Seems like the GPS Antenna cracks easily. IF you get the whole module it's like $160. Much cheaper solution is to replace the antenna for $4.75.
jody.paugh@fullerandsons.
