- Joined
- May 6, 2014
- Messages
- 247
- Reaction score
- 84
Hi, I seem to have misplace my Ground Station's antenna. Can anyone suggest a replacement (can't seem to find one through the DJI website, etc.) or even a better upgrade to the original? Thanks!
Any 2.4GHz antenna (for example, off an old wifi router) will be fine. Just make sure you get the correct center pin configuration for the connector. Some are male and some are female.doktorinjh said:Hi, I seem to have misplace my Ground Station's antenna. Can anyone suggest a replacement (can't seem to find one through the DJI website, etc.) or even a better upgrade to the original? Thanks!
Thanks! I thought that was the case, but I wanted to double check. I used a cloverleaf antenna (Rx) as a quick replacement in the field, but it certainly didn't have the reception distance that a 2.4GHz antenna would have.Any 2.4GHz antenna (for example, off an old wifi router) will be fine. Just make sure you get the correct center pin configuration for the connector. Some are male and some are female.
Also I have a spare original GS antenna if you want it. Just pay shipping. Although I'm in New Zealand the shipping will probably be more than the cost of an antenna!
azdrones said:I just crashed my Phantom 2 & Datalink and the props cut off both Datalink antennas (Air End). Will the WIFI antenna in my old laptop work ?? Any certain length etc? Thx
