Repaired dji phantom 3 ribbon cable
Discussion in 'Pro/Adv Discussion' started by keller123, Sep 5, 2016.
  1. keller123
    Hi I recently repaired my p3p ribbon cable and now the gimbal and camera are completely unresponsive!! wondering if any one else has had his problem. I've checked all the connections 3 times
  2. sonof40
    San Ramon, CA
    Maybe the cable wasn't the only repair needed.
  3. WetDog
    By 'checked the connections' you mean ran a continuity test on every wire from both connectors? If you didn't, you need to. If you did, you need to think, as sonof40 suggests, that something else went wrong.
    You can get those cables in a repair pack reasonably cheap. I repair many electronic things but hold the line at ribbon cables unless I really have to. They are complete PITA.
  4. Great_Lakes
    South Eastern Michigan
    Could be a bad "new" ribbon cable. I have the same issue after replacing mine so I ordered another one to replace the replacement! They're relatively cheap so it's worth finding out.
  5. Reed L
    Alta, Ca.
    As a side note, a few of the off brand ribbon cables fit perfectly but still don't have any power, so you really need to stick with DJI on this one part.
    NRJ likes this.
  6. keller123
    It is a genuine DJI I'm going to send it back and have them send me a new one thanks for all the replies
Similar Threads - Repaired dji phantom Forum Date
Phantom 1 repaired by DJI Phantom 1 Discussion Sep 22, 2014
Repaired drone different serial than DJI care purchase Phantom 4 Discussion Apr 2, 2017
Anyone get stress crack, after DJI repaired it? Pro/Adv Discussion Aug 11, 2016
Results after getting shell cracks repaired by DJI Pro/Adv Discussion Mar 23, 2016
DJI P3 Pro repaired Pro/Adv Discussion Jan 29, 2016
