Repair roadblock
Discussion in 'Pro/Adv Discussion' started by Cornmaize, Jun 15, 2016.
  1. Cornmaize
    Little while ago I descended into a bush. Didn't crash, flew out but I seemed to damage the magnet in the roll motor. (Basing this on others having the same problem).
    Acquired a new motor. Removed ribbon cable. Trying to take the old one off and after I removed the set screw from the pitch motor shaft I have been unable to remove the camera from the shaft. I've tried moderate force and heating the aluminum sleeve with a soldering iron. Every video I've seen the camera just slides off.
    Any suggestions would be appreciated.
  2. Amty lolo
    Change the roll arm too. Dont risk anything by heating unless u use a hydraulic press, then u can remove the old motor smoothly. Good luck
  3. Ted4797
    Florida and New York
    I had one that someone used loctite on. I used a small screwdriver and wedged it in very carefully. It slid off slowly
Similar Threads - Repair roadblock Forum Date
Standard North GA USA Repair Phantom 3 Help Wednesday at 4:26 PM
Anyone used these repair shops? Pro/Adv Discussion Jan 11, 2018
WiFi Module Repair Phantom 2 Vision + Discussion Jan 10, 2018
Repair services Pro/Adv Discussion Jan 7, 2018
Excessive repair costs....? Standard Jan 6, 2018
