Repair or Replace propeller motor????
Hi,
I recently had a run-in with my phantom and a tree. I just noticed that one of the motors is making a funny noise. I have a link to a 30 second video so you can hear the noise. I have a few questions:
1) I have already flown with this noise, and everything was fine. Should I continue to fly, or am I risking a failure?
2) Do I need to replace the motor? If so, is it a do-it-yourself project?
3) Can the motor be repaired? If so, is it a do-it-yourself project, and what do I need?
http://youtu.be/a_RrvsMIbcM
Thanks for any assistance with this problem
Gord
Unless removing obvious debris from the interior of the motor completely resolves the issue, you probably have, at least, damaged motor bearings. Might be best to just replace the motor ($23 USD). Remember your risking at least $500 of kit, maybe 3 times that amount, depending on the goodies you've added.
Steve
Gordo said:
Hi,
Gord
I went on Amazon to purchase the required supplies to DIY this project, and I am wondering which type of solder do I purchase?
Lead Rosin Core Solder
Lead-Free Solder
Electrical Rosin Core Solder
Lead-Free Solder Rosin Core
I think the list might be longer, ant thoughts?
