Thanks for the thoughts. These are the original DJI props and I have been using them for around 22 flying hours., since August, 2016. I will try my other props and if the problem is props, I will replace them. I have looked at the motor attachments and they seem OK.How many times have you had them on and off? Are they OEM DJI props?
These props have a life expectancy, and if yours might be getting worn out. Change them out with the spares DJI gave you or buy some more from DJI.
Buy Phantom 4 Series - Quick Release Propellers | DJI Store
I remove the after every flightI wonder if the plastic "quick disconnect" prop housings can become melted and distorted over time on the P4? With the motors heating up during flight and maybe having multiple flights back to back maybe it's possible.
Have you left them attached for quite a while or do you take them off between flights?
I also meant the plastic connector, just did not define correctly. You may be right, but see Rob1962 above. My temp was if 60's.That's good. But I was actually talking about the plastic connector at the top of the motor. I imagine the heat from the motor will prob take a tole sooner or later on them. Maybe?
Snow! That's all the white stuff in my yard I can't even give away! we also have 30-40C here, only it's in the minuses. The good things about is that we can snowmobile and there is no bugs!I generally leave them on as my flying area is 100000 hectares at my back door and I remove them every ten flights or so to inspect the retaining springs and check the plastic hub retaining stews (1.5mm) and no issues flying in 30-40C so far with 117klms on the P4. What is snow?
I didn't realize that they have a life expectancy. Is it measured in the number of flights, hours, or both? How many.
The way I heard it average life is 20 hours flight time, or 100 flights - or if stored 1 1/2 years.
I'm sure there are people that use them a lot longer but, that is the rule of thumb I use.
900 klms....I'm impressed. Hoping to head over east this winter with the wife as she has never seen snow either, should be a novelty of sorts. As for bugs, plenty of them and tiger snakes to keep you wary when flying.Snow! That's all the white stuff in my yard I can't even give away! we also have 30-40C here, only it's in the minuses. The good things about is that we can snowmobile and there is no bugs!
Now about the props and mounts, there made of nylon so that makes them pretty sturdy even with large temperature variations. I have over 900km on mine and they still look almost new.
