- Joined
- Nov 24, 2016
- Messages
- 13
- Reaction score
- 1
- Age
- 25
It says to contact dji, no firmware is being displayed just n/a
Did I just break the controller?
its a gl300a
its a gl300a
Wow funny, uhhh i used your gs_ofdm.bin firmware to downgrade. Professional - How to downgrade RC? from hereCan you share the rest of the story? What did you do right before this started occurring?
Yes it gives me.Did you try upgrading the remote controller after using that BIN?
Well it gave meSo, all was working well, you decided to randomly try to downgrade, and now the remote controller is beeping?
I'm pretty sure it was, but did I just like break my RC? :|Do you know if the gs_ofdm.bin was successfully installed?
Yes, it said successDid you install 1.03.2? If so, what did you see in the TXT file on the memory card?
Did a reset, now its stuck on a cyan light.Good. Now, start at step #14 here and try installing the latest version of the firmware on your remote controller.
BTW, I'm assuming you already installed the latest version of the firmware on your Phantom. If not, do that first.
I'm dumb zzzz, Not sure if I was impatient, Upgrade was just a green color without it making a result file. (Drone was on) So I decided to reset it using the c1 c2 iso record button.. and now its stuck on the cyan light..You did another reset? Hmm.
At the moment I am downgrading to 1.6.0 through the app, by holding the top right of the app and doing it there.When installing firmware from the memory card, a TXT file will be on your memory card if it tried to install the firmware. If you don't see a TXT file, then your remote controller did not try to install it for some reason.
If you still have a version older than 1.03.2 installed, you'll need to install 1.03.2 before you can install an update from the DJI GO app.
Alright for some reason the rc isn't updating after downgrading to 1.60? I'm using usbWhen installing firmware from the memory card, a TXT file will be on your memory card if it tried to install the firmware. If you don't see a TXT file, then your remote controller did not try to install it for some reason.
