Regaining control from rth
Manual says to flip s1 down and back up. But it does not clarify if it is one click or 2 clicks down.
Can anyone help here? Thanks.
Depends on how rth was initiated.
When rth was initiated automatical because of low battery status, s1 would still be in upper position. So to regain controle you have to put s1 one notch down en than up again.
When rth is initiated by your bij self putting s1 in the fale safe (=rth) position (lower position of s1), you just return s1 in upper position and you will regain control.
Helpfull?
Regards FA
Since you are referencing your manual, I assume your system is still set to the default PHANTOM mode? If so, it does not matter if you go 1 or 2 clicks down - either will regain control. Once control is regained you can/should set S1 back to the UP position.
BoguSlav
