Red lights stay on
Discussion in 'Phantom 2 Help' started by Mark Hansen, Dec 10, 2015.
  1. Mark Hansen
    Hello all, I have had this Phantom 2 for about a year and have flown it perhaps 25 times last year. now however
    there is a change, with remote turned on first, phantom is powered on it goes and does its tune and alternating
    lights flash after that the rear lights go Red after about 45 seconds they flash a fast green series of flashes and
    then go back to red. phantom wont spool up, but if i lift it about a foot off the ground and tilt it forward end down about 45 degrees the lights begin slow green flashing and while holding up and tilted the motors will start. i can then set it down and all seems well. flies right and switch remote off and will auto land. sometimes i have to lift it
    30 to 36 inches off the ground while tilting. I did do a recent update on the phantom 2 and recalibrated the remote. any thoughts appreciated and i have done this whole sequence in 3 different open fields in the desert
    with nothing by way of structures for at least a half mile in all directions. Thanks Mark Hansen Tucson Arizona.
  2. Mako79
    Sydney Australia
    Have you done a cold adv IMU calibration?
  3. Mark Hansen
    No, I had not. but, after your kind post i researched it a little and found a you tube video from "on the kitchen table" info and it explained it. so i did the IMU calibration and now it is perfect. Thank You
    so much! Again very many thanks, Mark,
Similar Threads - Red lights stay Forum Date
red lights Phantom 4 Pro Help Friday at 9:57 AM
Aircraft disconnected after software update, red RC LED, yellow blinking lights, PLEASE HELP Phantom 4 Pro Help Jul 22, 2017
HELP - Crashed / Repaired P4 - All Lights Red Phantom 4 Help Jul 19, 2017
phantom 4 front red lights Phantom 4 Discussion Jul 9, 2017
Solid 4 Red lights Standard/4k Discussion Jul 3, 2017
