Red LED’s after Compass Calibration?
Discussion in 'Phantom 2 Vision + Discussion' started by rwebcon, Sep 9, 2014.
  1. rwebcon
    Phoenix Arizona
    Just started to get funny results after compass calibration on my Phantom V2+. At the end of calibration I use to get a few seconds of no LED at all, then what appeared to be green red LED indicating a search for GPS signals. Recently at the end of compass calibration I’m seeing the LED’s blink red two time then green red as before. Does anyone know what the two red LED blinks at end of compass calibration means? Is this normal? I’m not seeing the red yellow as indicated in the manual as being a failed calibration.
  2. 4wd
    4wd
    North York Moors
    While doing the rotating especially the second part you often lose some of the satellites.
    Does it not find them and go back to green after a minute or so?
  3. rwebcon
    Phoenix Arizona
    Seems to go back to searching again. I will have to pay more attention to what happens after the two red LED's.
Similar Threads - Red LED’s Compass Forum Date
red lights Phantom 4 Pro Help Yesterday at 9:57 AM
Litchi has unpredictable server access Control (Go, Litchi, etc..) Aug 12, 2017
After being cleared, flight restrictions return with power up (battery change) Pro/Adv Discussion Aug 12, 2017
Standard Max altitude reduced Phantom 3 Help Aug 12, 2017
P4 Firmware Repaired P4P Returned...Now A Controller Firmware Issue Firmware Aug 11, 2017
