Red/green flashing light when charging controller?
When I plug in my RC to charge using an AC wall adapter, the LED status light on the controller flashes red and green very fast. However when I plug it in the charge to my computer, the LED is red as normal. Is 120V too much to charge the RC and that’s why the LED flashes red/green?
What kind of voltage does the wall adapter output? The Battery in the Standard controller is charged around 5 volts or there abouts.
Do you have another wall charger? Sounds like one you have is faulty. I use my iphone charger to charge my controller. I believe that one is 1A.
fmscott2. It’s the output of the charger that is important. I suspect your charger is not putting out enough amperage. I’ve tried using the phone charger that puts out 5volts @ 1amp and got the same flashing light indication as you described. I now use a charger with an input of 120volts, output is 5volts @2.3amps. This works fine.
wkflysaphan4
