- Joined
- Aug 23, 2016
- Messages
- 17
- Reaction score
- 4
- Age
- 67
I thought I would share a recent experience in hopes that if any of you have a similar experience you may be able to recover from it.
I have had my Phantom 4 about two months and have flown around 10 hours. I feel pretty confident in my abilities, but realize I have much more to learn.
Three days ago I decided I wanted to fly the drone low over a very beautiful river we have running through our county between high mountain peaks. I went down by the river to a beautiful flat rock and got my drone set up on the edge of the rock. Upon taking off the drone moved over the edge of the rock, paused (while it’s sensors wondered what the hell happened to solid ground) and slowly teetered into the water. After I caught my breath, I reached down and grabbed the landng gear. It was submerged about 3-4 seconds, or as I refer to it as “2-3 glugs”.
I'm convinced that the steps I took next helped me to save my drone from certain death. Maybe this will help you if you find yourself in a similar situation.
• Immediately after fishing my drone out of the water, I yanked the battery out. I felt that cutting electricity to any of the internal circuits immediately was the best thing I could do.
• I quickly turned it sideways and drained as much water as I could out of the now empty battery compartment. Once that slowed, I turned it in every other direction, and watched in horror as water came out in all directions. (Luckily this was crystal clear mountain stream water, not muddy river water or salt water!) I rushed to my car and proceeded to fill the battery compartment with paper towels and took any excess water off of the outside..
I then placed paper towels on the floor of my car, removed the propellers and turned the drone upside down to drain any liquid out of the motors.
It took me about 20 minutes to drive home, trying desperately to stay within the speed limits, and slow my breathing and heartbeats. Upon arriving home I pulled out all of my tools, which I commonly used for working on computers and laptops. Immediately I searched YouTube for a teardown video and was lucky enough to find the one linked here. https://www.youtube.com/watch?v=dA_MQiNmTUI
With the help of spudgers and some patience I was able to carefully disassemble the aircraft. The best thing you can do at this point is take photos of each step of the disassembly. You WILL forget where all of the antenna wires go, and which screws go into which holes. The pictures will save your sanity.
After I had disassembled the outer shell and carefully disconnected the wires I took each piece into the garage and, using my shop vac, blew compressed air into every possible nook and cranny. I was surprised at how much water still came out using that method.
I then made a quick trip to my local home improvement center and purchased some bags of desiccant called “DampRid”. Use this instead of rice. It’s much more effective.
Even after having blown out most of the excess water with the shop vac my biggest concern was the moisture inside the camera lens. I used a hair dryer to see if that could help evaporate some of the liquid but it was only partially effective.
I took the camera lens and placed it in a small Tupperware container with the desiccant on the bottom and a small piece of shop towel over the desiccant and sealed it. I used additional containers of dessicant for the top of the drone, camera/gimbal assembly and battery. After 12 hours I first checked the camera lens and it was totally clear of any moisture. The same was true for the other large components.
I then began the process of reassembling. Because of the photos I had taken, this actually went quickly and easily. Yesterday I was finally ready to test the craft to see if I had been able to save it. I'm happy to report that it seems to be as good as new! If you are ever in this situation, I wish you the same good fortune!
P.S. Now I am older and my close-up eyesight might not be as good as it once was, but having a pair of inexpensive jewelers magnifier headband is a lifesaver. http://amzn.to/2fLcdtp
