Rechargeable Batteries in controller
Discussion in 'Phantom 2 Vision + Discussion' started by Jayfdee, Jan 5, 2016.
  1. Jayfdee
    Morecambe Bay UK
    I use rechargeables in my controller, but at 1.2 volts, should I use 1.5 volt non rechargeable?
    I get a very good range,but occasional RTH due to no signal.
  2. N017RW
    Palm Beach Co.- FL
    Battery voltage is regulated internally to about 3.3vdc.
    So long as you are not getting Low Battery indication from the controller you are fine.
    There is NO impact on range or performance short of the warning mentioned.
    Jayfdee likes this.
  3. RoyVa
    Virginia
    Outside temperatures and humidity play a part in how much range we get. Some days are better than others. If you've had your quad for a while sometimes making mods to the antennas give you a lot better distance. I changed my antenna out for a DBS Itelite and tripled my range. They come with all the connectors and wiring need to make the mod. There are you tube videos that show how to do the job too.
    Antennas are distance the battery provides the times.
Similar Threads - Rechargeable Batteries controller Forum Date
Ok to use rechargeable batteries in the transmitter? Phantom 2 Vision + Discussion Oct 17, 2014
Question about rechargeable AA batteries. General Discussion Sep 9, 2014
Best rechargeable batteries for receiver? General Discussion Apr 23, 2014
rechargeable remote batteries Phantom 2 Vision + Discussion Apr 20, 2014
Mega Range Junkie modified argtek w/ 3 sunhan boosters and rechargeable battery Classifieds Jan 4, 2017
