Receiver wire torn off
Discussion in 'General Discussion' started by merzbow, Dec 18, 2014.
  1. merzbow
    I had to transport the dji on a plane in a hurry so I unscrewed the landing gear and propellers, but I forgot to take the tape off the wires. One of the wires managed to get torn off. Any way to fix this? Can it still fly?
  2. FlyingFox
    Cheshire UK
    It can be spliced and repaired , you need to,fine someone who can solder proficiently
  3. N017RW
    Palm Beach Co.- FL
    The antenna wires are actually coax.
    A fine center conductor surrounded by insulation and the a fine wire braid with again outside insulation.
    Not something you should attempt to splice and then expect your quad to operate properly.
  4. CityZen
    NYC
    Now would be the perfect time to look in to antenna upgrades! :)
  5. burlbark
    Thats no good... The antenna will have to be replaced. This requires quite a bit of work. I have not done this job yet.... Main board will need to be lifted to gain access to the on board rx. Then adhesive will need to be removed to allow removal of the SMA and the new antenna will go back down in place. I figure on a good hour of work or $70.
  6. CityZen
    NYC
    If it's an early single-antenna P1, then it's a bit easier - no need to lift the main board.
  7. lake_flyer
    The Low Lands
    a new receiver board isn't very expensive and comes with the antenna's attached. Only problem is to get it somewhere. DJI?
Similar Threads - Receiver wire torn Forum Date
Looking for a P2 Antenna wire that attaches to receiver Classifieds Feb 14, 2016
Phantom 2 receiver wire broke Phantom 2 Discussion Sep 1, 2015
Help please...Trying to replace antenna receiver wire. Phantom 2 Vision + Discussion Dec 4, 2014
Replacin receiver antenna wire Phantom 2 Vision + Help Dec 4, 2014
Phantom 2 w/ Wireless Receiver on a SmallHD AC7 Monitor FPV (First Person View) Nov 4, 2014
