If one powers the controller and the quad and fails to mount the ant. on the transmitter will it burn out the receiver module
Thanks Bob
Thanks Bob
Not knowing the specifics of DJI's design we can only generalize. I'll err to the conservative and say that brief periods are ok given the low power of these systems.
How brief? A couple of minutes is typical but again it depends on design.
No antenna mounted or a short are the same, nearly 100% power reflected back into the PA with only a phase difference between the two scenarios.
This causes the transistor to heat up and is the cause of damage. Chronic damage becomes accumulative and over time will reduce time to failure.
Other more sophisticated designs measure the SWR from a mismatch or module temperature and reduce power to protect the output section of the TX.
So if you caught the problem before excessive heating you'll be fine.
