Real or hoax? Phantom lifts chair.
Discussion in 'General Discussion' started by FC40 Pilot, Mar 4, 2014.
  1. FC40 Pilot
    UK
  2. Big Ben
    It's 'real' in the sense the Phantom lifts something in the shape of a chair. Just don't try to sit on it. The styrofoam bits it's made of won't carry your weight.
  3. scole
    that's not a real chair, its foam I think, but still a fun idea
  4. Suwaneeguy
    that plastic chair probably weighs about two pounds.
    Otherwise the phantom could not get the altitude it did.
  5. jodaddy23
    tucson arizona
    why have fifty feet of rope ? fake or stupid
  6. Firestat
    Columbus, Ohio USA
    Seems that the rope would weigh more than the chair. Not sure why they had it so long. Anyway, it was pretty cool.
  7. iResq
    Annapolis, Maryland
    Perfect audio track.
  8. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    Seems the light is pointing at the camera irregardless of angle and for the rope is miraculously visible form pretty much any distance. And somehow the Phantom can miraculously stay balanced while the chair attached to it gets sucked downwind. Spend 20 minutes shooting with your Phantom pulling up a string then another 20 minutes with Adobe After Effects and you too can do this.
  9. BruceTS
    Granada Hills CA
    The video is real, but the chair is fake. It's so obvious the way the chair floats around that it is made of Styrofoam or balsa wood and just a prop. Try sitting in it and bet it falls apart, still a fun prank to pull off.
    Hehe I should do a similar video with my air jacks, hook my Phantom to the front bumper of my truck, then lift the front off the ground.
  10. OI Photography
    Clarksville, TN
    I was sooo hoping he put it right in to that window after lifting it off the ground.
  11. Big Ben
    A giveaway is the segment between 40-50 seconds after the ascent where the Phantom hovers in GPS mode and the 'chair' is then blown quite a bit downwind to the left of the frame fitting something very light like a styrofoam object.
    Also the movement/tumbling when descending and the vibrating of the back in the last second of the video when it hits the ground.
Similar Threads - Real hoax Phantom Forum Date
Phantom4 Realtime FPV feed - Woodland test Photos and Video Sunday at 4:08 PM
Standard Glare problem...seems there is no real issue Phantom 3 Help Aug 7, 2017
Need help - REALLY weird issue with phantom - Will not hover AT ALL Phantom 1 Help Aug 5, 2017
I'm really considering giving up my dream job... Real Estate Aug 5, 2017
SOLD Epson Moverio BT-300 Augmented Reality Smart Glasses (AR/Developer Edition) Classifieds Aug 3, 2017
