Re Configure Gimbal
Vermont
After a crash I am wondering if my gimbal is working correctly. It spins up and jerks around for a second or two, then settles into position. The control on the transmitter seems to work, but seems ridiculously fine. Can only get the Go Pro into the horizontal position by carefully moving the lever very, very slightly in the mid control position...Is this normal?
Also I hooked it up to the Assistant Software...and I am not seeing any movement of the gimbal while adjusting the Gimbal Config sliders...should I see some movement here? When connected they sit in the mid position for all three controls.
You need to recalibrate your X1 stick in assistant software
cgarner1
