RC lost signal and will not reconnect
Discussion in 'Pro/Adv Discussion' started by Wormfood, Jan 13, 2016.
  1. Wormfood
    Just unboxed my p3a 7 days ago and had about 8 flights with no problems. Today I was checking out the flight simulator and my RC lost signal and the AC started to beep. When I went to shut it off the vps was hot enough to burn your hand. Now all it will do is beep non stop and will not connect with RC. All of this happened while it was sitting on my table.
  2. bobmyers
    San Antonio, TX
    Always best to use a small fan on the aircraft when it is on and sitting on the bench with no air flow. Keeps all the electronics cool. Shut down the VPS in the app and see if that helps.
  3. Wormfood
    VPS was off when this happened.
  4. AsiaFlyer
    Koh Samui, Thailand
    The VPS module is also where the Lightbridge system is housed, you might have cooked it
  5. Wormfood
    Also when the p3a is on and you move the ac by hand the gimbal jerks around and will not move smoothly.
  6. Wormfood
    Is it normal for them to get that hot?
  7. AsiaFlyer
    Koh Samui, Thailand
    No, how long were you using the simulator for?
  8. Wormfood
    My son was using it for about 15 minutes when it lost signal the first time.
  9. Wormfood
    I called dji and all they told me was not to turn it back on because it might be a fire hazard and that I needed to send it to them.
  10. Wormfood
    I was hoping for an easy fix or maybe a setting that was wrong. At least it wasn't in the air when this happened.
  11. Barnero
    May I ask what aVPS and a p3a are. Probably a dumb question, but.
  12. alokbhargava
    San Francisco, CA
    VPS: it's a visual positioning system mounted at the bottom of phantom. It's effective to hold the phantom in case GPS is not available such as inside house.
    p3A: it's Advance version of Phantom 3
Similar Threads - lost signal reconnect Forum Date
Help! RC Signal Lost and can't reconnect Pro/Adv Discussion May 12, 2016
Advanced RC lost signal and will not reconnect Phantom 3 Help Jan 13, 2016
Phantom 3 SE will not lost signal Phantom SE Jan 7, 2018
Standard signal lost Phantom 3 Help Jan 4, 2018
Advanced Signal lost on p3 advanced. Phantom 3 Help Dec 17, 2017
