RAW Photo Question - Red dots
Discussion in 'Editing (Photo and Video)' started by Nickster, Jun 28, 2016.
  1. Nickster
    Dayton, OH
    My RAW photos keep coming in with red dots in random spots where it is very dark or black on my photos I take in raw. Any ideas on how I can get rid of them?
  2. 4wd
    4wd
    North York Moors
  3. Nickster
    Dayton, OH
    I will try and get one on with the website version.
  4. jlazz447
    any update to this? my RAW photos are covered in red dots in black areas
  5. Nickster
    Dayton, OH
    Exactly what I had. Not sure what to do.
  6. ikonane
    I've got the same problem. A lot of them as well.
    DNG Cleaner removed maybe two of hundreds of dots.
    #6 ikonane, Jul 7, 2016
  7. julesytime
    Melbourne
    Sounds like clipping. Basically Photoshop shows you when the highlights or shadows are too extreme. In this case your image has parts that are too dark. If you look at the histogram, on the left the graph will be touching the side and be quite steep?
    If this is the case try decreasing your shadows and highlights, maybe exposure if necessary. If you're happy with how dark it is, on the top corners of the histogram are two triangles. Click them each once and it will turn off the clipping warning.
  8. ikonane
    No, I think it's a faulty sensor or something with the ISO in the black areas.
    A lot of people are having the same problem:
    red / white dots in video
    What the heck is this caused by? Red dots...everywhere.
    Photo w/red and white dots on the left | DJI Phantom Drone Forum
    DJI_0062 | DJI Phantom Drone Forum
    I've seen threads on other forums as well.
  9. With The Birds
    Australia
    Increase exposure at time of capture if possible without blowing highlights. Use DNG cleaner as suggested. Also, as you have observed, the noise is random. If you take multiple frames you can stack, align and blend in Photoshop. Set your opacity to 100% for image 1 then half for each following frame in stack. i.e. 100, 50, 25, 12, 6 for 5 frames. You will be amazed how clean the resultant blended image will be.
    scootrkitz likes this.
Similar Threads - RAW Photo Question Forum Date
P4P - Raw Photos & Adobe Camera Raw Questions Phantom 4 Discussion Mar 30, 2017
Photos Supposed to be RAW Only - Keep getting JPEGS? Phantom 4 Pro Help May 12, 2017
Timelapse / Interval Timer rate in RAW photo mode Phantom 4 Pro Discussion Mar 9, 2017
I cant see my RAW photos in my computer Pro/Adv Discussion Feb 20, 2017
Photo Issues: JPG and RAW mixed up Phantom 4 Pro Help Jan 14, 2017
