Range P3S vs P4 both stock
Oklahoma
Well did a range test today to compare my stock P4 to my stock P3S. Made it 14162 feet compared to my P3S 13040 feet. My question is I was in Sport mode and it took 5:16 to warm up and fly that distance and only had 58% battery to return on where the P3S took 5:23 with 80% battery left. Does Sport mode use that much more power???
Try a cold IMU calibration. Shouldn't take 5 mins. to warm up.
Reactions: IsraeliDroneFlyer70
Wow! I'm lucky to get 3000ft on my P3S!
The area you use it in makes all of the difference. Look back at my map (over a lake) and then his. There is nothing around. A busy wifi area will kill a drones signal. Heck, even a microwave oven will mess with your video feed.
is it the cold imu cali a trick to fly that far or what you mean? dont und erst and you
Sent from my HUAWEI P7-L10 using PhantomPilots mobile app
Calibrating the IMU while the drone is cold will allow it to warm up quicker than if it was calibrated at a warmer temperature.
shimuafeni fredrik
