- Joined
- Oct 8, 2015
- Messages
- 55
- Reaction score
- 2
- Age
- 58
What’s the furthest anyone has got their p3se in an urban area ? Mine is 700 meters and it loses signal and want to return. They should go further right?
Depends of your location. FCC or CE.What’s the furthest anyone has got their p3se in an urban area ? Mine is 700 meters and it loses signal and want to return. They should go further right?
The difference between a P3SE and P3S is quite simple. Your maximum distance is 2.5 miles. In addition, you have Vision Positioning System. And your camera has a resolution of 4K.Hi! And a good Sunday to everyone! I have a P3S and one time now about a Month and a half ago went out on the S side of town and even with the forest ,that day went 3,700 ft distance but usually my average elsewhere is 1500 - 2100 ft. it varies. I still would like a S.E and actually not sure...Can you create a Pre-flight w Way Points BEFORE you fly? and not have to fly it first like you do with the Phantom 3 Standard?
Do the SE batteries last longer? is 600.00 -650.00 the going price $ Range for the SE
(I made the little Phantom Animation below, I made a 3D model-Phantom)....( One of the propellers fell off during upload!)
Thanks for the reply and I also wanted to share my Sunday mornings Video-The difference between a P3SE and P3S is quite simple. Your maximum distance is 2.5 miles. In addition, you have Vision Positioning System. And your camera has a resolution of 4K.
But ... you still use the same app. And if you want to program your route in advance, I advise you to keep your P3S and use Litchi.
Btw, your battery is also the same.
Wow! That's great for a Standard!My P3S will go 3 miles in country setting and about half that in a city.
That's impressive... You probably have a modded controller. I have a windsurfer and only can go up to 2150 feet.My P3S will go 3 miles in country setting and about half that in a city.
I have the Itelite antennae. Mine went about 2500' feet stock and about 6-7000 ' with wind surfer. I cannot emphasize enough location of flight makes all the difference for the range. Where I normally fly I'm basically limited by my battery life. At max range I'm still pegged on telemetry and normally down one bar on video. At 13,800 feet I was getting smart RTH activation. I've since disabled it and made it to 15,000 feet before the spincter factor kicked in.That's impressive... You probably have a modded controller. I have a windsurfer and only can go up to 2150 feet.
